Article Slideshow not running
- HeymannM
Topic Author
- Visitor
Article Slideshow not running was created by HeymannM
got JP Ecology and cant get the article slideshow running.
The smooth gallery runs perfect. I deactivate the smooth gallery and activate the article slideshow ... and end up at a blank page.
I have MySQL 5 and php4, but i parsed this with AddType application/x-httpd-php5 .php .php4 .php3 .php5 in my .htaccess.
Still end up at a blank page.
Ideas anyone?
Matthias
Ideas anyone?
Matthias
12 years 6 months ago
#1
- Joomlaplates
- Visitor
Replied by Joomlaplates on topic Re:Article Slideshow not running
Please check if your site is really running PHP5. > Joomla Help > System > PHP
And the most problem is the wrong // .htaccess // upload.
You have to create a new htaccess.txt file with ASCII mode and upload it to your server.
After that rename the htaccess.txt to .htaccess and it works.
#2
- HeymannM
Topic Author
- Visitor
Replied by HeymannM on topic Re:Article Slideshow not running
wow ... so simple ... running now!
thanks
thanks
#3
- HeymannM
Topic Author
- Visitor
next problem
During the development of the page (in a sub-folder) everything was ok. Now the page is ready and I routed the domain to the sub-folder to make it public.
On the start page, everything is fine, but on the single pages ...
- on category blog pages it runs fairly ok, but in some articles in the blog, the plugin code apears.
- on the articles, the show stops completely.
- on core pages like poll and login, lost PW its shows an error for all pix
(Warning: imagecopyresampled(): supplied argument is not a valid Image resource in /mnt/web4/12/76/51355676/htdocs/galeerenfahrt-de/cms/modules/mod_lofarticlesslideshow/libs/phpthumb/GdThumb.inc.php on line 217)
How can I fix this? Have a look at www.galeerenfahrt.de please?
Edit: sorry, had to deactivate the ArticleSlideshow now, as more and more error mssages came up, also after sending a message throug the standard contact form. No way to leave it public like this
Matthias
Matthias
- Joomlaplates
- Visitor
may it´s a conflict between other installed plugins that are using the same Javascript framework.
Please disable all the plugins or special modules and try it again.
#5
- Hrvoje
- Visitor
Replied by Hrvoje on topic Re:Article Slideshow not running
Hi
I install the template, but when i´m running the site comes this message:
Parse error: syntax error, unexpected T_CLASS in /homepages/7/d146383293/htdocs/hompegae/modules/mod_lofarticlesslideshow/helper.php on line 20
When i disable the module \"Lof ArticlesSlideShow Module\" everything works
help please
help please
12 years 5 months ago
#6
Moderators: Joomlaplates, joomlaplates
