TOPIC: [SOLVED] Header in the middle and between lines
Header in the middle and between lines 3 years 11 months ago #1
  • Projekt Partner
  • Projekt Partner's Avatar
I know there was a post already. but I did not get it.
does that only work, if you show the titel of the page?
I would like to have h3 so formatted. Is that possible?
Or how should I do it.
Thanks!
Header in the middle and between lines 3 years 11 months ago #2
Add this html code to your article or module and it should works
<h3 class="uk-panel-title">Enjoy Our Gourmet Dinner</h3>
The following user(s) said Thank You: Projekt Partner
Header in the middle and between lines 3 years 11 months ago #3
  • Projekt Partner
I did. In the HTML code of the article. Nothing changed.
Header in the middle and between lines 3 years 11 months ago #4
Live Url please
Header in the middle and between lines 3 years 11 months ago #5
  • Projekt Partner
URL landing page: landing page
on all pages , like this one : page
"Die Gemeinde" should be like "Take a look at our design"
Header in the middle and between lines 3 years 11 months ago #6
As i told you above, please insert your title with this code into your Joomla article.
After that you have to disable the org. Joomla artile title
<h3 class="uk-panel-title">Die Gemeinde</h3>
Header in the middle and between lines 3 years 11 months ago #7
  • Projekt Partner
I did all that, what you said:
result:
Header in the middle and between lines 3 years 11 months ago #8
  • Projekt Partner
The pictures are not going through.
Header in the middle and between lines 3 years 11 months ago #9
  • Projekt Partner
I put in HTML of the article page the code.
I turned "Show Title" in the options of the Article on Hide.
Result... not what I wanted. Sorry.
Header in the middle and between lines 3 years 11 months ago #10
Hi again,
sorry I could not see the class and the headline in your site, see image below
1.) Goto system config and disable the tiny editor
2.) Now insert this code below for your headline
Header in the middle and between lines 3 years 11 months ago #11
  • Projekt Partner
it is "Bürgerinfo/statistische Daten"
thats what I did.
I have the JCE editor.
Maybe I changed, while trying, something else... but what?
Thanks.
Header in the middle and between lines 3 years 11 months ago #12
As I told you above, please disable the "stupid" Editors and insert the code direct in html modus without any editor
Header in the middle and between lines 3 years 11 months ago #13
  • Projekt Partner
That is exactly what I did!
Sorry!
I disabled the editor and put the line, as you can see above, in the HTML code!
Sorry if that is bothering you.
Header in the middle and between lines 3 years 11 months ago #14
  • Projekt Partner
do not bother anymore.
I put in the custom.css
h3{
text-align:center;
overflow:hidden;
h3 span{
display:inline-block;
position:relative;
h3 span:after, h3 span:before{
content:" ";
display:block;
height:1px;
width:1000px;
background:black;
position:absolute;
top:50%;
h3 span:before{
left:-1010px;
h3 span:after{
right:-1010px;
now it works. Thanks!
[SOLVED] Header in the middle and between lines 3 years 11 months ago #15
  • Projekt Partner
