TOPIC: Menu Module and Widget not visible on mobile
Menu Module and Widget not visible on mobile 2 years 10 months ago #1
  • amandat
  • amandat's Avatar
Hello, my Main Menu is sitting in the "Menu" Module but does not appear on my mobile phone, (i can see the menu on my desktop and laptop). I also have a widget with text sliding in which also does not appear on my mobile.
Secret text
thank you!
Amanda.
Menu Module and Widget not visible on mobile 2 years 10 months ago #2
Hi Amanda,
password/user doea not match.
By the way, please read these instructions to add a mobile menu.
www.joomlaplates.com/support/documentati...etup-the-mobile-menu
Menu Module and Widget not visible on mobile 2 years 10 months ago #3
  • amandat
  • amandat's Avatar
thank you and apologies!
Secret text
i have an offcanvas menu although i can't seem to get it to work for the widget i created. does it work for widgets?
also the Widgetkit "slideshow settings show a number of effects available. some do not seem to work. is this because the widgetkit "Free" download only supports Slideshow (lite)?
Thank you.
Amanda.
Menu Module and Widget not visible on mobile 2 years 10 months ago #4
Hi Amanda,
I can see the offcanvas menu link, see image attached.
If you publish a mobile logo, then the menubar have more space.
Warp 7 Templates provides the logo-small position, where you can display an alternative logo image for smaller viewport sizes.
The widgetkit lite has not effect limitations.
Maybe you get a conflict with other slideshow ( bt slider) maybe thats the reason why some effects are not working.
Menu Module and Widget not visible on mobile 2 years 10 months ago #5
  • amandat
  • amandat's Avatar
Hello again,
after stripping back everything that could be conflicting with the slider effects, i ended up reinstalling the widget.. I think i found what the problem was. It appears that the effects were hard to see because i had the same pictures loading in the widget. Once i changed the pictures for three different ones you are able to see the effects clearly. Thanks for your help!
