TOPIC: logo does not load on mobile
logo does not load on mobile 2 years 9 months ago #1
  • amandat
  • amandat's Avatar
Hello, i have a slideshow widget set up on my home page with a gallery widget set up which has an image of my logo identical to the 1st class template set up.
my problem is that whilst the slideshow widget loads on a mobile phone the gallery image does not load. this leaves me with a very empty looking slider.
Can you please take a look on a moble phone and advise how i can make the gallery image appear on a mobile phone also?
thanks!
Secret text
logo does not load on mobile 2 years 9 months ago #2
Warp 7 Templates provides the logo-small position, where you can display an alternative logo image for smaller viewport sizes.
The following user(s) said Thank You: amandat
logo does not load on mobile 2 years 9 months ago #3
  • amandat
  • amandat's Avatar
is there a way to remove the slider from mobile view only?
logo does not load on mobile 2 years 9 months ago #4
You can add a module class suffix, to hide the slider in mobile view.
See image below
logo does not load on mobile 2 years 9 months ago #5
  • amandat
  • amandat's Avatar
hi again and thank you however, it doesn't seem to work for me.
my layout does look different to yours though.
logo does not load on mobile 2 years 9 months ago #6
But you must have a module class suffix field
logo does not load on mobile 2 years 9 months ago #7
  • amandat
  • amandat's Avatar
thank you. there is no "module class suffix" field under advanced (perhaps this relates to widgetkit2?) There is only a "Header Class" which doesn't work to style the entire module.
i was able to add the module class suffix to the widget itself under "HTML class" and this worked beautifully.
thank you. :)
