TOPIC: [SOLVED] module frontend editing
module frontend editing 1 year 5 months ago #1
  • cindydp
  • cindydp's Avatar
The icon to edit modules in the frontend are shown when i am logged in but when i click on it, it doesn't work.
What can be the reason? It is not possible for the super user as another group of users.
I think everything is well on the permission settings.
module frontend editing 1 year 5 months ago #2
  • cg
  • cg's Avatar
I have got the same Problem (THEME: HOST).
Switching the editor-settings to "editor - none", did not help.
For myself (super user) this isn't a problem, but what about anybody else making some changes.
For a non super user I think you Permission must be Manager or higher.
module frontend editing 1 year 5 months ago #3
1.) Delete all the layouts you dont need:
2.) Make sure that the content output is NOT disabled
The following user(s) said Thank You: cg
module frontend editing 1 year 5 months ago #4
  • cindydp
  • cindydp's Avatar
You can not remove the default layout and i just have one more that i use.
The system output is not disabled.
module frontend editing 1 year 5 months ago #5
the layout > startsite has the system output disabled.
Please remove the startsite layout if you dont needed.
BTW: The system output must be enabled to edit the modules
module frontend editing 1 year 5 months ago #6
  • cindydp
  • cindydp's Avatar
Thank you, this was the answer to my problem!
