TOPIC: background
background 2 years 2 weeks ago #1
  • nico@ikanda.be
  • nico@ikanda.be's Avatar
We are trying to place a picture in the background of the Agency Template, but the picture doesn't cover the whole section of bottom B.
How can we solve this so there are no white space left on the top and the bottom of the picture.
See: tapscreen.eu -> the contactform
background 2 years 2 weeks ago #2
Sorry I cant see any issue, did you fixed it.
background 2 years 2 weeks ago #3
  • nico@ikanda.be
Hi, no, not solved.
I have atteched a screenshot. I'm want to remove the white areas above and below the 'meer info nodig?' picture.
background 2 years 1 week ago #4
you can not use 2 background images in a row.
You need one color background and then one background. Otherwise you have to change the transformatation
background 2 years 1 week ago #5
  • nico@ikanda.be
Hi, sorry, still struggling with this topic.
Ok, I understand that we can't use 2 images in a row, but could we for instance also change the color of the white space?
What do you mean by changing the transformation?
Thanks in advance for you reply.
background 2 years 1 week ago #6
Hi again,
1.) The background can be changed in customizer
2.) Change the padding to for the section if the transformation is not showing the image
Sorry the transformation can be changed only in css
