I have a question about the background in the Agency template.
When I enable a rocksprocket module in bottom A, everything is ok.
However, when I enable a SP page builder in bottom A, I see dotted lines on the top and the bottem.
How can this be explained and how can this be solved as we would like to use the SP page builder module.
Also this same SP page builder module has been used on top C without any problem.
I tried to mail you 2 screen shots to explain better the problem, but it didn"t work...
Thanks in advance for your help
