TOPIC: Background images are not scaling on iPad
Background images are not scaling on iPad 1 year 11 months ago #1
  • bloos
  • bloos's Avatar
Hi There,
The background images are not scaling on the iPad. So the original size is displayed and that's not pretty. How can I change that? The site is on www.blooscreatie.nl.
Background images are not scaling on iPad 1 year 11 months ago #2
please make sure that you map is responsible and max width of 100% and have no fixed pixel size.
www.joomlaplates.com/support/documentation/setup-a-google-map
Background images are not scaling on iPad 1 year 11 months ago #3
  • bloos
  • bloos's Avatar
Hi! Thanks for your feedback and I've altered that within de Google Maps module… but that was not really my problem… I was referring to the background images. Those images look great on the desktop but they are not scaled on the iPad. So that looks weird. I've added a screendumb but you can check for yourself on www.blooscreatie.nl. I've had this problem before with a Joomlaplates-template and it was solved then… but I can't remember how…
Background images are not scaling on iPad 1 year 11 months ago #4
  • 411415
  • 411415's Avatar
sorry I cant see any problems, see image attached
Background images are not scaling on iPad 1 year 11 months ago #5
  • bloos
  • bloos's Avatar
Yes, I see that it works fine in iPad mode, but on an actual iPad it’s different...
Background images are not scaling on iPad 1 year 11 months ago #6
  • 411415
  • 411415's Avatar
which IOS and which Browser is installed on Ipad.
Maybe some javascript or css is blocked by IOS
Background images are not scaling on iPad 1 year 11 months ago #7
  • bloos
  • bloos's Avatar
The latest IOS version and Safari...
Background images are not scaling on iPad 1 year 11 months ago #8
Please add this code to your css/custom.css
@media screen and (max-width: 768px) {
#top-a, #top-b, #top-c, #top-d, #bottom-a, #bottom-b, #bottom-c, #bottom-d {background-attachment:scroll !important}
BTW: Wow nice site!
Background images are not scaling on iPad 1 year 11 months ago #9
  • bloos
  • bloos's Avatar
Thanks, that's seems like the code but… were do I find the custom.css? It's not in the template css files. I've tried adding a custom.css with the code myself but that didn't work…
Background images are not scaling on iPad 1 year 11 months ago #10
  • bloos
  • bloos's Avatar
I've had this problem before on www.olavboerkamp.nl and there it was sufficient y adding this code tot te templates css files… but on blooscreatie.nl it doesn't do the trick…
Background images are not scaling on iPad 1 year 11 months ago #11
Background images are not scaling on iPad 1 year 11 months ago #12
  • bloos
  • bloos's Avatar
Yep, this was exactly how I added the custom.css file but it din't have the wanted effect…
Background images are not scaling on iPad 1 year 11 months ago #13
please delete the Joomla and Browser Cache and delete the cache from IOS Safari
Background images are not scaling on iPad 1 year 11 months ago #14
  • bloos
  • bloos's Avatar
Did that already. Still no luck…
Background images are not scaling on iPad 1 year 11 months ago #15
  • bloos
  • bloos's Avatar
But perhaps you provide me with other solutions?
Background images are not scaling on iPad 1 year 11 months ago #16
Hi again,
sorry I have no more solution right now.
And I cant see any issues on MAC OSX with Safari. Its the same rendering engine then Tablets have.
Background images are not scaling on iPad 1 year 11 months ago #17
Background images are not scaling on iPad 1 year 11 months ago #18
  • bloos
  • bloos's Avatar
I've added one of the suggested code o the forum you recommended and that did it:
css:
.hero {
background-image: url('...');
background-size: cover;
.no-touch .hero {
background-attachment: fixed;
Thanks for your endless patience and support. You really helped me out! Again, thanks!
