TOPIC: [SOLVED] template alpha read more css
template alpha read more css 1 year 4 months ago #1
  • caroline.b
  • caroline.b's Avatar
I want to change the layout of a read more link, and i started to copy article.php in my style.
So i used my class in custom.css - but it's not working
.uk-button{
border: 5px solid #6f7a40;
color:#ff0000;}
can someone help me?
template alpha read more css 1 year 4 months ago #2
  • cg
  • cg's Avatar
i think you only need an "override" of the article.php, when you want to change the position or the general behavior of the "read more" button.
This is a much more complex task!
For color and size styling you can use the "custom.css".
Then use the code you write before. That will work!
Greeting from Germany,
Christian
template alpha read more css 1 year 4 months ago #3
  • caroline.b
It's not working :(
this is my css-code
.uk-button
color:#ff0000;}
template alpha read more css 1 year 4 months ago #4
  • cg
  • cg's Avatar
yo write the code in the custom.css of your template folder?
template alpha read more css 1 year 4 months ago #5
  • caroline.b
yes
template alpha read more css 1 year 4 months ago #6
  • caroline.b
template alpha read more css 1 year 4 months ago #7
  • cg
  • cg's Avatar
Oh, have you got a live URL?
We have to analyse this width developer tools.
template alpha read more css 1 year 4 months ago #8
  • caroline.b
No, sorry it's on my local server
template alpha read more css 1 year 4 months ago #9
  • cg
  • cg's Avatar
In line 19 there is an unused "*/" comment please delete it.
To make sure that there is not a mistake in your CSS-File please check the syntax.
W3C-Syntax CHecker
template alpha read more css 1 year 4 months ago #10
  • caroline.b
i deleted the "*/" , the same :(
template alpha read more css 1 year 4 months ago #11
  • caroline.b
But is it correct that i only need tor use
.uk-button
it's not with .uk-button a
template alpha read more css 1 year 4 months ago #12
  • cg
  • cg's Avatar
Yes, i use the following code to style my buttons:
/* Buttons */
.sprocket-grids-b-readon, .uk-button {
   background: #DC143C !important; ...
Maybe a post of your complete CSS as an attachment will help to fix it.
template alpha read more css 1 year 4 months ago #13
btw did you add the "uk-button" class to the article.php. Otherwise it makes no sense to add a class to your css file
template alpha read more css 1 year 4 months ago #14
  • caroline.b
i have to copy this file to templates/name-template/styles/name-style/ and here i put the file article.php?
is it possible that the search in your forum is not working?
template alpha read more css 1 year 3 months ago #15
The forum search is different to the site search:
The following user(s) said Thank You: caroline.b
template alpha read more css 1 year 3 months ago #16
  • caroline.b
it's working
thanks for your help
[SOLVED] template alpha read more css 1 year 3 months ago #17
  • caroline.b
