TOPIC: [SOLVED] Menu itesm not showing on mobile
Menu itesm not showing on mobile 1 year 1 week ago #1
  • erik1234
  • erik1234's Avatar
We bought your template and installed it. However the menu is not showing on the mobile versions of the site. It does show normal on laptopscreens etc. But on mobile its just a white space. Any tips on how to fix this?
OK fixed it
www.joomlaplates.com/support/documentati...etup-the-mobile-menu
Is the module published?
[SOLVED] Menu itesm not showing on mobile 1 year 1 week ago #2
