TOPIC: [SOLVED] Layout module setting not work
Layout module setting not work 5 months 3 weeks ago #1
  • tangryuno
  • tangryuno's Avatar
I've installed the theme on a yet created website, so I've installed only the template.
Everything is ok but any change made in layout will not take effect
Why?
thanks
www.2mconsulting.biz/homepage
Layout module setting not work 5 months 2 weeks ago #2
The following user(s) said Thank You: tangryuno
[SOLVED] Layout module setting not work 5 months 2 weeks ago #3
  • tangryuno
