TOPIC: [SOLVED] Slider @ Top B on mobile
Slider @ Top B on mobile 4 months 1 week ago #1
  • kente2t
  • kente2t's Avatar
Hello again,
I am using the Slider function to display a couple of photos on the entry page of my web site, [url=http://]e2t.se[/url]. This works perfect on pc and ipad. On my mobile phone, a Samsung S7, the slider photos display perfect when the mobile is in landscape mode, but when the phone is in portrait mode the photos are displayed in full width but truncated in height. This is the same result as I get when I run your Biz demo on the phone.
This is not a big problem, but maybe you have a solution or suggestion?
Regards
Kent Ericsson
Slider @ Top B on mobile 4 months 1 week ago #2
I would disable the slider in phone view, because there is no solution. The images get shrinked tothe width of the screen > 352px
You can setup this in the Theme settings > Options > Modules.
Slider @ Top B on mobile 4 months 1 week ago #3
  • kente2t
  • kente2t's Avatar
Thank you for the reply. I tried do disable the Slider photos for the phone, but the result got so dull so I decided to keep it as it works perfect if you turn the phone to landscape mode.
[SOLVED] Slider @ Top B on mobile 4 months 1 week ago #4
  • kente2t
  • kente2t's Avatar
