TOPIC: where are the fonts?
where are the fonts? 3 years 5 months ago #1
  • kirszenb
  • kirszenb's Avatar
I have the JP - Blog template and it's supposed to have 500 Google Fonts.
My Joomla article editor does no show me multiple fonts. Where/how can I access and use these additional fonts?
Thanks, John
where are the fonts? 3 years 5 months ago #2
you can setup the fonts in customizer:
www.joomlaplates.com/support/documentati...the-customizer-warp7
where are the fonts? 3 years 5 months ago #3
  • kirszenb
  • kirszenb's Avatar
Hi, I'm not sure how to access the customizer.
From my main menu, I can go Extensions, Templates to Styles & Templates.
From Templates I select mine = Jp-blog Details and Files ...
On that page, across the left from top to bottom are: css, html, images, js, layouts, less, roksproket, styles, warp
Under warp I have, congig, gzip, js, layouts, src, systems, vendor
I'm not sure where to go from here. I just want different fonts and font sizes to use on my articles.
thanks, John
where are the fonts? 3 years 5 months ago #4
Hi again,
watched the video?
The customizer is in template styles > Options.
Anyway, you can not use different fonts for different articles.
Maybe you should customize the css files then und import the font you want.
where are the fonts? 3 years 5 months ago #5
  • kirszenb
  • kirszenb's Avatar
Will the "JCE Editor" plugin work with this jp-blog template?
So much can be done with the Customizer. That short 5-min video does not due it justice. Is there a User Guide (pdf?) for that application that I can download and study?
Many thanks, John
where are the fonts? 3 years 5 months ago #6
Yes the JCE is working with our theme.
But not recommend to use it, because of security reason.
The most things in customizer you dont need to know and different from theme to theme.
Here are more instructions:
getuikit.com/v2/docs/tutorials.html
where are the fonts? 3 years 5 months ago #7
  • kirszenb
  • kirszenb's Avatar
Thanks for the help. My only issue is with the URL links (color & font size) auto changing after update.
Please go to this page and read it. I have there described in detail...
flatearthlunacy.com/index.php/2-uncategorised/54-test
Sorry to keep bothering you.
Thanks again, John
where are the fonts? 3 years 5 months ago #8
Hi John,
no problem you do not bothering us.
But you can not insert any "pre" formatted text style into the editor!
1.) The paragraph text font is always definied by CSS
2.) You can insert the text with an extra inline style like this:
<p style="font-family:Helvetica,Arial; color:red">This is your pre styled text</p>
But I think it depends on your editor. The editor is cleaning your style:
Maybe a helpful article:
www.joomlaplates.com/support/documentati...content-was-cleansed
