TOPIC: [SOLVED] Error after installation... ????
Error after installation... ???? 10 months 4 days ago #1
  • 2ndskin
  • 2ndskin's Avatar
I get this issue after installing the quickstart! How can i fix this on the front side? Thanks in advance!
Warning: getimagesize(C:\xampp\htdocs\2ndskin/images/joomlaplates/demo-001.jpg): failed to open stream: No such file or directory in C:\xampp\htdocs\2ndskin\plugins\system\bdthemes_shortcodes\config\inc\tools.php on line 396
Notice: Trying to access array offset on value of type bool in C:\xampp\htdocs\2ndskin\plugins\system\bdthemes_shortcodes\config\inc\tools.php on line 397
Notice: Trying to access array offset on value of type bool in C:\xampp\htdocs\2ndskin\plugins\system\bdthemes_shortcodes\config\inc\tools.php on line 398
Notice: Trying to access array offset on value of type bool in C:\xampp\htdocs\2ndskin\plugins\system\bdthemes_shortcodes\config\inc\tools.php on line 400
Notice: Trying to access array offset on value of type bool in C:\xampp\htdocs\2ndskin\plugins\system\bdthemes_shortcodes\config\inc\tools.php on line 402
Notice: Trying to access array offset on value of type bool in C:\xampp\htdocs\2ndskin\plugins\system\bdthemes_shortcodes\config\inc\tools.php on line 404
Error after installation... ???? 10 months 4 days ago #2
1.) Please use XAMPP with another PHP Version, maybe 7.2. No provider is on PHP 7.3
2.) Please disbable the error reporting in XAMPP it is only needed for developer
3.) Setup the Joomla Error Reporting level to > BASIC
The following user(s) said Thank You: 2ndskin
[SOLVED] Error after installation... ???? 10 months 4 days ago #3
  • 2ndskin
  • 2ndskin's Avatar
