TOPIC: [SOLVED] Reduce margin and pading
Reduce margin and pading 5 years 2 months ago #1
  • keralahaus
  • keralahaus's Avatar
hi i tried a lot to reduce the margin and pading under the slidecontent.
. mit custom.css i tried. but not working. can u help me. my website: www.keralahaus.com
Reduce margin and pading 5 years 2 months ago #2
Hi there, I dont know which slideshow it is but you have a "h3" headline in your slideshow.
See image attached, red marked. ( Remove your h3 and the gap is gone)
The following user(s) said Thank You: keralahaus
[SOLVED] Reduce margin and pading 5 years 2 months ago #3
  • keralahaus
