TOPIC: [SOLVED] Display Module - Mobile Only
Display Module - Mobile Only 4 years 3 months ago #1
  • czm2000
  • czm2000's Avatar
I'm trying to display a module only when the site is viewed on a mobile device. I've tried adding the bootstrap module class suffix in the advanced tab and nothing happens. I've tried everything from visible-phone to visible-xs and visible-sm to hidden-desktop and nothing will work. What am I doing wrong?
Thanks for your help.
Display Module - Mobile Only 4 years 3 months ago #2
  • czm2000
  • czm2000's Avatar
Anybody? Any help is greatly appreciated.
Thanks for your time.
Display Module - Mobile Only 4 years 3 months ago #3
The Fashion Template is not using the "bad" blowed up bootstrap.
You can handle the media queries in an easy way.
Add this code to your file > css/custom.css
.visible-phone {
  display: none !important;
.visible-tablet {
.hidden-desktop {
.visible-desktop {
  display: inherit !important;
@media (min-width: 768px) and (max-width: 979px) {
  .hidden-desktop {
  .visible-desktop {
    display: none !important ;
  .visible-tablet {
  .hidden-tablet {
@media (max-width: 767px) {
  .hidden-desktop {
  .visible-desktop {
  .visible-phone {
  .hidden-phone {
And now you have the choice to show the module in desktop only or in mobiles devices and so on.
Therefore add a module class suffix to the module like this:
Module Class Suffix = hidden-desktop
Display Module - Mobile Only 4 years 3 months ago #4
  • czm2000
  • czm2000's Avatar
Awesome! Thank you so much.
[SOLVED] Display Module - Mobile Only 4 years 3 months ago #5
Display Module - Mobile Only 4 years 3 months ago #6
  • czm2000
  • czm2000's Avatar
I just tried it and it's not working. I inserted the code you gave me in the custom css area and saved it (first screen shot)
I then went to the module and added hidden-desktop to the module class suffix (second screen shot)
But the phone number still shows on the desktop version of the site (third screen shot) and it should be hidden, correct?
What else can I try?
Thanks for your help,
-Chris
Display Module - Mobile Only 4 years 2 months ago #7
  • czm2000
  • czm2000's Avatar
Please see above post, as that didn't work. Any additional help is greatly appreciated.
Thanks
Display Module - Mobile Only 4 years 2 months ago #8
Live Url please to check the code!
Display Module - Mobile Only 4 years 2 months ago #9
  • czm2000
  • czm2000's Avatar
******dental.com
Thanks
Display Module - Mobile Only 4 years 2 months ago #10
I have no access, because we are living in Germany!
Display Module - Mobile Only 4 years 2 months ago #11
  • czm2000
  • czm2000's Avatar
Woops. I'm sorry about that. We were getting tons of hacker attempts from all over the world. It was just easier to block everyone who wasn't located in the US.
I've unblocked Germany. Please try again if you could.
Display Module - Mobile Only 4 years 2 months ago #12
  • czm2000
  • czm2000's Avatar
It's been almost 6 days since I apologized and unlocked Germany so you could help. When will you be able to look at why it's not working for me?
Display Module - Mobile Only 4 years 2 months ago #13
Hi again, ok now it works and I can see your website.
But I could not see any issue, did you fixed it?
Display Module - Mobile Only 4 years 2 months ago #14
  • czm2000
  • czm2000's Avatar
No, not fixed yet. I was waiting for you to take a look to make sure you didn't see anything wrong. I added a test module. I had it disabled but I re-enabled it. You'll see a phone number on (or around) the guys forehead. I have that set to hidden-desktop. Please reference post #6 to see that I have everything setup correctly and it's still showing on desktop. The odd thing is it disappears in mobile view. But then again, so does most of the stuff in the header so that may be related to the functionality of the template?
Can you please take a look as soon as possible (not wait days). I know how busy you must be, but I can't leave that phone number overlapping his forehead too long since it looks bad. Thanks for understanding and for your help.
Display Module - Mobile Only 4 years 2 months ago #15
Hi there, ok now I see the issue.
Please take a "space" before you add the module class suffix: [space]hidden-desktop
Display Module - Mobile Only 4 years 2 months ago #16
  • czm2000
  • czm2000's Avatar
That did it! Thanks so much :-)
