TOPIC: Change module width in Footer position
Change module width in Footer position 2 years 7 months ago #1
  • v8tom
  • v8tom's Avatar
I use this beautiful Template.
How can I change the module width in the Footer position?
I use the Menu items in the Module (pic. 01), but the menu's items overflow (pic. 02)
I need the menu' items in the between red lines.
I can't use this Module another position (pic. 03) because I need the items in Horizontal.
Change module width in Footer position 2 years 7 months ago #2
live url please.
Change module width in Footer position 2 years 7 months ago #3
  • v8tom
  • v8tom's Avatar
Secret text
Change module width in Footer position 2 years 7 months ago #4
add this css code to your css/custom.css
.tm-footer .uk-panel {
width: 1100px;
margin: 0 auto;
Change module width in Footer position 2 years 7 months ago #5
  • v8tom
  • v8tom's Avatar
Yess, thanks (Peter?) :)
(littlebit change: I use max-width:...)
On the Front Page (
Secret text
) working fine, but if I open an elements in menu: overflow again in the footer.
Please, open a menu item, and check footer.
example:
Secret text
OR
Secret text
Change module width in Footer position 2 years 7 months ago #6
please do not edit the org css files like theme.css, because these files will be overwritten while compile the less files or use th customizer..
Create a custom.css, here is a video how it works
The following user(s) said Thank You: v8tom
Change module width in Footer position 2 years 7 months ago #7
  • v8tom
  • v8tom's Avatar
It's magic. Working perfectly.
Thanks your help.
