TOPIC: [SOLVED] Template jp-fire
Template jp-fire 1 year 3 months ago #1
  • vvfetr
  • vvfetr's Avatar
Hi, I have uploaded the JP-FIRE joomla template and I have installed the QuickTime zip file in a local server XAMMP (the last version php 7.3.1.0).
I created a database in my hosting package, and configured it all, however now when I open the administration panel in Joomla there isn't the JP-FIRE template but just the default template of Joomla. In the folder for my localhost (xammp/httpdocs/hostname/template) the template JP-FIRE is present.
Best regards,
Fabio
Template jp-fire 1 year 3 months ago #2
please make sure you did all the steps, like here
www.joomlaplates.com/support/documentation/install-demo-content
Maybe you have forgotten to tick the sample data
Template jp-fire 1 year 3 months ago #3
  • vvfetr
  • vvfetr's Avatar
Hi, sorry for my english.
I'm sure I did all the steps, like here
The problem is probably the sample data: if I tick the sample data the installation doesn't finish (My PC is working for about one hour....without result)
Template jp-fire 1 year 3 months ago #4
The following user(s) said Thank You: vvfetr
[SOLVED] Template jp-fire 1 year 3 months ago #5
  • vvfetr
  • vvfetr's Avatar
[SOLVED] Template jp-fire 1 year 3 months ago #6
  • vvfetr
  • vvfetr's Avatar
Thanks for your help. I changed the php.ini parameters. Now the template is installed.
