TOPIC: Read More - Link
Read More - Link 5 years 9 months ago #1
  • PhilippM
  • PhilippM's Avatar
you have created such a nice button as a readmore-link. Unfortunately I cannot find a way to use your buttons for the integrated read-more function. Is there any possibility?
Thanks a lot!
Read More - Link 5 years 9 months ago #2
The read more button are only available if you have a custom class at a link like this:
<a href="/jp_flexible/index.php" class="button-primary">Read more..</a>
But this read more class is not available for Joomla content read more.
Read More - Link 4 years 8 months ago #3
  • blue_peter
  • blue_peter's Avatar
hi.
i tried to apply the class you suggested (class="button-primary") directly into the file named: BLOG_ITEM.PHP
located in the position: JP-FLEXIBLE > WARP > SYSTEM >JOOMLA > LAYOUT > COM_CONTENT and it works.
thanks.
Read More - Link 4 years 8 months ago #4
PLease do not customize the org Warp files, you will lost them when you update the Warp.
Use override system, like this
yootheme.com/themes/documentation/custom...verride-system-files
Read More - Link 4 years 8 months ago #5
  • blue_peter
hi, thanks for your quick reply.
i've used override way, and works great.
so, the solution is:
- copy the file BLOG_ITEM.PHP from JP-FLEXIBLE > WARP > SYSTEM >JOOMLA > LAYOUT > COM_CONTENT into
JP-FLEXIBLE > HTML > COM_CONTENT (overwrite the old file)
- change <p class="links"> into <p class="links button-primary">
p.s. great job: this template is very useful.
