TOPIC: [SOLVED] Site SEO error
Site SEO error 5 years 1 month ago #1
  • joomlqueen
  • joomlqueen's Avatar
Hi there, my site url is: nostosrestorations.ca/
I have a small problem that I would like to fix and I am wondering if you would be able to give me some direction. I am using the Flexible template.
My Problem:
I am running the site pages through the Bingmaster SEO Analyzer and all the pages are returning with this error:
The <img> tag does not have an ALT attribute defined.
This offending image appears to be the background image that I have on all pages. <img src="/images/background3.jpg" class="bg">
Is there a way to modify the CLASS tag with an ALT tag to stop these SEO errors from appearing?
Site SEO error 5 years 1 month ago #2
the background image need no alt tag, it doesnt matter. And please dont believe everything of SEO.
But if you like you can add an image tag to the bg image.
Open the file > layouts/template.php and search for img tag and insert the "alt" tag like this:
<img src="/images/background3.jpg" alt="Background Image" class="bg">
Site SEO error 5 years 1 month ago #3
  • joomlqueen
Thanks so much, that worked perfectly! I just ran the check again and the SEO error doesn't appear any longer.
Yes, I agree, I don't worry too much about the SEO Analyzer but my client is a little tech savy so I want to make sure that this issue doesn't come up when he runs this test himself, which I know he will do.
Great template, works perfect for what my client needed and his odd logo.
[SOLVED] Site SEO error 5 years 4 weeks ago #4
