TOPIC: [SOLVED] Background color of the 2nd level menu sidebar
Background color of the 2nd level menu sidebar 4 years 11 months ago #1
  • jancu
  • jancu's Avatar
how/where can I change the background color (currently white with opacity) of the 2nd level menu within the sidebar?
Regards,
Herbert
Background color of the 2nd level menu sidebar 4 years 11 months ago #2
This must be donw in with CSS.
Live Url please, where we can see the menu.
But you can try it to do by yourself with firebug help.
Background color of the 2nd level menu sidebar 4 years 11 months ago #3
  • jancu
  • jancu's Avatar
OK thanks. I've got it.
In "blue.css" the background color can be changed here:
#jp-left .menu-dropdown .dropdown-bg > div {
	background: #fff;
[SOLVED] Background color of the 2nd level menu sidebar 4 years 11 months ago #4
  • jancu
  • jancu's Avatar
[SOLVED] Background color of the 2nd level menu sidebar 4 years 11 months ago #5
Please do not edit the org files.
Add your custom code to the file: css/custom.css
background: #fff;
