TOPIC: Installation Problem
Installation Problem 4 years 6 months ago #1
  • mose1606
  • mose1606's Avatar
i can´t install the sample data, it doesn´t run with joomla 2.5 and joomla 3x. I tried both versions. Joomla installation don´t work when i try to install with the demo files. The system is loading and loading and after a while i´m back on the site where i can choose to install with demo files or whithout. I always come back to this side. I work with Xampp 3.2 and go step by step like in the description.
So i don´t know where the problem is. Hope you can help me.
Installation Problem 4 years 6 months ago #2
we recommend the UWamp, its a portabe Apache and you can switch between the SQL and PHP Version,
www.uwamp.com/en/
But you can try this trick too:
www.joomlaplates.com/forum/j3-ultimate/4...-6-installation#6795
