TOPIC: Problem with template
Problem with template 3 years 7 months ago #1
  • joomlqueen
  • joomlqueen's Avatar
www.furryfriendsanimalrehab.com
I tried to install the new Joomla version patch 3.6.3 to this site which is running the Flexible template. The install seems to work however once completed I get an error and the whole site bombs. I am not having this issue on any of my other sites. This appears to be a template issue perhaps. I have tried doing the install a few times but continue to get this error.
The error I get after the upgrade is:
Error displaying the error page: Call to a member function getTag() on null: Error decoding JSON data: Syntax error
Is there anything that could be causing this that you can help me with? We love this template and certainly don't want to have to switch it to something else just for a small upgrade.
Thanks for any help you can give.
Problem with template 3 years 7 months ago #2
I have checked the theme with Joomla 3.6.3 and I could not see any issue!
Please check the WARP version of your theme and make sure you have the latest version.
If not, you can update the Warp for free, here are the instructions
Problem with template 3 years 7 months ago #3
  • joomlqueen
Thanks for your help, I tried to upgrade the WARP but this didn't seem to solve the issue. In the end, I got frustrated and rebuilt the whole site again. Hard to say what was causing the issue but I did notice once I rebuilt the client had a huge amount of text and dashes in her meta area on every page. Thanks again for your speedy reply.
