TOPIC: [SOLVED] How to change from vertical to horizontal menù
How to change from vertical to horizontal menù 1 year 8 months ago #1
  • Stefano Guida Meloni
  • Stefano Guida Meloni's Avatar
Hi guys,
I have just bought the template.
I have one problem about the main menù in position 'top_main'... it is displayed in vertical but I want to have it in an horizontal position.
I have tried to put in module setting 'nav-pills' (with space before) but nothing is changed...
How can I fix it?
How to change from vertical to horizontal menù 1 year 8 months ago #2
  • cg
  • cg's Avatar
Hi Stefano,
in the Demo-Version of Folio the menu is horizontal as required.
I think your menu-items are too long.
Greetings,
cg
How to change from vertical to horizontal menù 1 year 8 months ago #3
Hi Cg,
also with small menu-items is still the same...
How to change from vertical to horizontal menù 1 year 8 months ago #4
  • cg
  • cg's Avatar
Hi Stefano,
the site is not online yet?
How to change from vertical to horizontal menù 1 year 8 months ago #5
Now is online:
www.pitrisconi.com/
How to change from vertical to horizontal menù 1 year 8 months ago #6
  • cg
  • cg's Avatar
Hi Stefano,
add the following code to your custom.css.
As you see in the attached picture, my browser (chrome) shows the menu-items horizontal.
Make a test in Firefox and IE too.
ul.uk-nav.uk-nav-parent-icon.uk-nav-side {
    display: -webkit-box;
    display: -ms-flexbox;
    display: flex;
[SOLVED] How to change from vertical to horizontal menù 1 year 8 months ago #7
How to change from vertical to horizontal menù 1 year 8 months ago #8
Thank you! Now the menu is perfect!
