TOPIC: [SOLVED] Default color choices ...
Default color choices ... 1 year 3 months ago #1
  • ofisboy
  • ofisboy's Avatar
Is it possible to change any of the default color schemes to something else? Or, add an additional color scheme?
Default color choices ... 1 year 3 months ago #2
Which Theme
Default color choices ... 1 year 3 months ago #3
  • ofisboy
  • ofisboy's Avatar
The Folio template. I would like to be able to get the color scheme to coordinate with the color of the logo, if possible.
I must be doing something terribly wrong. In addition to the above issue, I created an article page I no longer want but when I try to unpublish it or put it in the trash it brings the whole site down. Once it's unpublished or in the trash I get a 404 - Page not found error on the site. It appears on the front page and now I can't get rid of it. Can you figure out where I might be going wrong?
Default color choices ... 1 year 3 months ago #4
1.) Colors can be changed in Customizer
www.joomlaplates.com/support/documentati...the-customizer-warp7
2.) If you disable an article which is set as default in menu item, then the site crashed!! But should be clear!
Default color choices ... 1 year 3 months ago #5
  • ofisboy
  • ofisboy's Avatar
The Customizer only tells me that "The current theme is not customizable." There are no options to customize in the Folio template. I created a new style and then edited the theme.css. I now have the colors I want but if there's supposed to be a different method of customizing it please let me know. I thought I would have options to select from rather than editing the theme.css directly. Anyway, it's done.
I also couldn't get rid of the page that was causing the site to crash so I wound up re-installing the quickstart. It wasn't tied to any menu so I don't know why I could delete it but that's corrected now, too.
Default color choices ... 1 year 3 months ago #6
Please read the troubleshooting guide
yootheme.com/support/question/75099
[SOLVED] Default color choices ... 1 year 3 months ago #7
  • ofisboy
  • ofisboy's Avatar
I have the Folio quickstart installed on a practice domain with a blank index.html file to hide the site. It seems this is not allowed as the customizer doesn't recognize it as a standard file. I removed the index.html and now everything works perfectly. Thank you!
