TOPIC: [SOLVED] "Projects" module gone from 2 to 3 columns!
"Projects" module gone from 2 to 3 columns! 1 month 3 weeks ago #1
  • Allioth
  • Allioth's Avatar
I don't know if others are having the same issue: after installing the template, everything looks exactly as it should. A perfect mirror of the demo installed on Joomlaplates website.
The problem arises when I go into the PROJECTS Rok-Sprocket module (Mosaic setup) and - even without changing a single thing - I click on SAVE.
Once I reload the page, the module is no longer on two columns, but it changes into three.
I originally thought I touched something I shouldn't have... So, to remove any possible exterior fator, have reinstalled the whole template on a sub-directory, from scratch and without ANY modification at all. Went straight into the module, saved it with no modifications at all, and BOOM! Same situation: from two to three columns...
I need it to stay on two columns... Please could someone help?
Thank you in advance,
Ralph
"Projects" module gone from 2 to 3 columns! 1 month 3 weeks ago #2
sorry this is working only with a small modification of the file > options.xml in the folder
...\components\com_roksprocket\layouts\mosaic\options.xml
Add this line to the file
<option value="2">2</option>
The following user(s) said Thank You: Allioth
[SOLVED] "Projects" module gone from 2 to 3 columns! 1 month 3 weeks ago #3
  • Allioth
  • Allioth's Avatar
