TOPIC: [SOLVED] Breadcrumbs Font color
Breadcrumbs Font color 3 years 5 months ago #1
  • edesigner
  • edesigner's Avatar
Using theme color white, breadcrumbs font color is white on this background color of very light grey. On most displays it couldn't be seen. On customizer I was not able to change either the background color nor the font color. Best would be to set the font color to blue. Is there any way to change the font color of it?
Breadcrumbs Font color 3 years 5 months ago #2
you can setup the color in Customizer, see image below
The following user(s) said Thank You: edesigner
[SOLVED] Breadcrumbs Font color 3 years 5 months ago #3
  • edesigner
