TOPIC: space between modules
space between modules 1 year 9 months ago #1
  • griffin
  • griffin's Avatar
I need to reduce the space between the menu and the content section, as you can see in my screenshot. The problem is only with the smartphone view. Can you help me?
Thanks!
space between modules 1 year 9 months ago #2
Live Url please
space between modules 1 year 9 months ago #3
  • griffin
  • griffin's Avatar
Secret text
thanks!
space between modules 1 year 9 months ago #4
Try this code below and add the css style to your css/custom.css
@media screen and (min-width: 768px) {
.main-outer {
padding: 0 !important;
space between modules 1 year 9 months ago #5
  • griffin
  • griffin's Avatar
Thanks!
I put the code -using FTP client - into templates/jp-gusto/css/custom.css, but nothing happens. (the permissions are ok, 755)
I try to put the code into the template settings, using administrator area of the site (where we add the google analytics code, p.e.) and I see the code at the footer in home page.
Regards,
Jo
space between modules 1 year 9 months ago #6
1.) Disbale the "Always compile LESS", see image below
2.) Check the css/custom.css file, because it is not available
Your site > right click > show source > click the custom.css file
space between modules 1 year 9 months ago #7
  • griffin
  • griffin's Avatar
I done.
I try to insert the code in a custom.css file, but notjing happens.
The problem is the distance between offcanvas menu and the main section with the gallery (only with a smartphone view)
I don't find the solution...
(thank you)
space between modules 1 year 9 months ago #8
give me admin access please.
Send the username and password to:
support@joomlaplates.com
space between modules 1 year 9 months ago #9
  • griffin
  • griffin's Avatar
I'm sorry, but I had to make some updates on joomla. (I need to change server)
As soon as everything is ready I will communicate the access data
Thanks!!!
space between modules 1 year 9 months ago #10
  • griffin
  • griffin's Avatar
Hi, now the site is ok, has been moved to another server and I have updated to the latest version of joomla.
I send you te access data,
Thanks!
Secret text
space between modules 1 year 9 months ago #11
I have add this code and it works
@media screen and (max-width: 768px) {
.main-outer {
The following user(s) said Thank You: griffin
