TOPIC: Suckerfish without arrows
Suckerfish without arrows 8 years 4 months ago #1
  • mrpereda
  • mrpereda's Avatar
Hello, I\'d appreciate if somebody can help me to remove the white arrows from the suckerfish...The problem is that I have too many items in the menu and it jumps to a second line. (without the arrows will fit for sure) Is there anyway to adjust it in one line? of if not, to delete the arrows? Thank you
Re:Suckerfish without arrows 8 years 4 months ago #2
  • Joomlaplates
  • Joomlaplates's Avatar
if you dont want to show the arrow you have to edit the:
> your template / superfish / css / superfish.css ( line 138)
and delete the background at this style:
background:url(\'../images/arrows-ffffff.png\') no-repeat -10px -100px; /* 8-bit indexed alpha png. IE6 gets solid image only */
Re:Suckerfish without arrows 8 years 4 months ago #3
  • mrpereda
  • mrpereda's Avatar
Thank you very much! :)
When the arrows disappear they left an empty space at the right, so the menu still doesn\'t fit. if someone has the same problem, to remove this gap go to line 125 and make the value 2.25 smaller.
.sf-menu a.sf-with-ul {
padding-right: 2.25em;
min-width: 1px; /* trigger IE7 hasLayout so spans position accurately */
