TOPIC: No spacing after paragraphs
No spacing after paragraphs 6 years 11 months ago #1
  • brandonkasper
  • brandonkasper's Avatar
I'm having trouble adding spacing after paragraphs. Here is an example page: www.plymouthmnchiropractic.com/pain-relief
As you can see, all of the paragraphs are smashed together and the template.css file does nothing to the page when I change the padding or marging parameters. Could someone give me a pointer on how to add spacing after my paragraphs?
Thank you.
Brandon
No spacing after paragraphs 6 years 11 months ago #2
  • Online
Use "Shift" + "Return"
No spacing after paragraphs 6 years 11 months ago #3
  • brandonkasper
It had been a while since I've used CSS and it was very late last night when I posted. I was trying to get my desired results by using margin. I should have been using padding, and now I'm getting my desired results.
Hope this post helps anyone who is working long after they should be in bed and is running into the same problem I did.
Brandon
