TOPIC: OLD JQUERY / SLIDESHOW NOT WORKING
OLD JQUERY / SLIDESHOW NOT WORKING 6 years 6 months ago #1
  • stefanieexakt
  • stefanieexakt's Avatar
Hey There,
I recently purchased the 2.5 version of JP Health Care template. I tried to set up the smooth gallery extension that comes with the template but once installed and set up - the slider would not rotate, manually or automatically.
I then attempted to install and set up Unite Nivo Slider (an alternate slideshow). Again, I could get this installed, set up and even showing on the homepage BUT the slides will not animate/rotate manually or automatically.
When I posted in the Unite Nivo Slider forum requesting help to get the slider rotating, the plugin author informed me that jp_health_care/superfish/js/jquery.js is a VERY OLD version of Jquery and therefore the slider would not work.
Can you please help me either:
1. Get the smooth gallery working OR
2. provide instructions on how I would update the superfish jquery to a newer version
Any help is appreciated.
Here is my site: http://www.elanguagesinc.com/j25/
OLD JQUERY / SLIDESHOW NOT WORKING 6 years 6 months ago #2
I visited your site and no jquery is loaded. Threfore the superfish is not working.
The org slideshow is working with mootools.
But you can update to the newer version of jQuery if you replacing our old javascript files from folder:
jp_health_care\superfish\js\jquery.js
to the newer one here:
jquery.com/download/
OLD JQUERY / SLIDESHOW NOT WORKING 6 years 5 months ago #3
  • stefanieexakt
Ok, I am trying to use the Smooth Gallery plugin that came with the JP Health Care template. I installed and activated the Mootools Enabler/Disabler plugin which tells me mootools is working. However, my slideshow is still not rotating (manually or automatically).
I also just upgraded from 2.5.4 to 2.5.11, which I was hoping would kick start the slideshow but it is still a static image.
Please help! Thanks
OLD JQUERY / SLIDESHOW NOT WORKING 6 years 5 months ago #4
Please try to add a "jpg" image and not a "png" file.
OLD JQUERY / SLIDESHOW NOT WORKING 6 years 5 months ago #5
  • stefanieexakt
Changed the images to jpgs and the slider is still not rotating.
Not sure if this makes a difference, I do not have the "Use mootools" setting as it is shown in the "jp_smoothgallery_how_to.pdf". I am using mootools however.
Any other suggestions?
OLD JQUERY / SLIDESHOW NOT WORKING 6 years 5 months ago #6
Please mail me you admin account to:
support@joomlaplates.com
