TOPIC: 2 or more templates on the same domain
2 or more templates on the same domain 4 years 9 months ago #1
  • tonymina
  • tonymina's Avatar
I am currently using the Health Care template and would like to change it to the Exquisite template using most of the articles in Health Care. Will I be able to do this? If so, how can I do this?
2 or more templates on the same domain 4 years 9 months ago #2
You can use our themes on as many concurrent sites as your membership licenses allow. However, you can change the themes of your current sites and use new ones at anytime.
2 or more templates on the same domain 4 years 9 months ago #3
  • tonymina
  • tonymina's Avatar
Both templates have a module position named "user 1". Currently, I have a module in my healthcare template pointing to user1. How can I point a new module for my exquisite template point to user1?. Thanks.
2 or more templates on the same domain 4 years 9 months ago #4
You can insert the "user1" module position into the module position field. If you cant select the module position then type it into the field.
