TOPIC: Responsive Layout and Sidebars Problem
Responsive Layout and Sidebars Problem 3 years 11 months ago #1
  • tvm
  • tvm's Avatar
Is there any way to hide the menu but not the sidebars on tablets? It looks like that changing the values for sidebar-a or sidebar-b in the back-end (Templates: Edit Style | Layouts | Grid) does not affect the front-end at all.
Responsive Layout and Sidebars Problem 3 years 11 months ago #2
You can play around with the grid at customizer > Advanced > Breakpoints
And the "medium" size should be the Table view!
The following user(s) said Thank You: tvm
Responsive Layout and Sidebars Problem 3 years 11 months ago #3
  • tvm
  • tvm's Avatar
Thanks a lot for the answer. I am not sure, but I think there is a bug in the CSS. When the html or body width is set to 1024 pixel (iPad landspace) the menu is above the content. In my opinion, the menu should be still on the left side. Also in the back-end (Extensions | Templates | Templates) the link to your website is wrong: www.JoomlaPlates
Responsive Layout and Sidebars Problem 3 years 11 months ago #4
here are the part of the media queries when max-width is > medium
>> your template/less/theme.less > line 84
Copy and paste the code above to your css/custom.css and play with the width.
In this point I mean the max-widh, like this:
@media all and (max-width: 1024px) {
	#jp-left { position: relative!important; width: 100%!important; height:auto }
	#jp-left .inner { position: relative; margin: 0 0 20px 0; width: 100%; padding: 0; text-align: left; height: auto; float:none!important }
	#jp-right { position: relative; width: 100%; margin: 0px auto!important; height: auto; padding-left:0!important }
