TOPIC: [SOLVED] display
display 3 years 10 months ago #1
  • lasserrema
  • lasserrema's Avatar
after updating new wrap version (6.4.7 ) , I met an issue concerning the width of images in the top of screen. I don't know why.
Normally I followed up the differents steps explained in your documentation.
Can you support me about the subject ?
Best regards
display 3 years 10 months ago #2
Live Url please and screenshot of the issue what do you mean exactly.
And the Warp update has nothing todo with the images on your site!
display 3 years 10 months ago #3
  • lasserrema
our URL website is : IPEF
The width of the sliders doesn't match with the width of the screen
Thank you by advance for your support
Best regards
display 3 years 10 months ago #4
the issue is based on stupid bootstrap.
Please add this syntax to your css/custom.css
.container {width:auto !important}
And then please add a module class suffix mod-blank to the slider
display 3 years 10 months ago #5
  • lasserrema
Thank you very much.
All is all right now for all page.
Best regards
[SOLVED] display 3 years 10 months ago #6
  • lasserrema
