TOPIC: [SOLVED] error after logout
error after logout 3 years 10 months ago #1
  • lasserrema
  • lasserrema's Avatar
I use in my website the connexion module. When I logout and come back on the main menu, the sliders are not correct.
Here is a picture with the errors met
https://www.dropbox.com/s/glo7f3dqj4xqsws/error%20after%20logout.JPG?dl=0
How to solve this difficulty?
Thank you by advance
Best regards
error after logout 3 years 10 months ago #2
Hi there, thanks for the image but I need a live url where I can see the website and analyze the source code.
It seems to be a script conflict between the slider and any of your installed extensions.
error after logout 3 years 10 months ago #3
  • lasserrema
Here i the URL link
website
I hope that it will help you
Best regards
error after logout 3 years 10 months ago #4
Please provide me a username and password, because I need to login and logout to see the issue!
You can use our secret text, only I can see the username and password
error after logout 3 years 10 months ago #5
  • lasserrema
sorry for my delay.
Secret text
Best regards
error after logout 3 years 10 months ago #6
It seems to be a HTML issue with your login modul. ( See image attached > red arrows)
Which login module is in use? PLease publish the org Joomla login module and try again.
The following user(s) said Thank You: lasserrema
error after logout 3 years 10 months ago #7
  • lasserrema
I remove my login module and regenerate.
All it's all right now.
Thank you
[SOLVED] error after logout 3 years 10 months ago #8
  • lasserrema
