TOPIC: [SOLVED] Background of menu on subpages (not home)
Background of menu on subpages (not home) 11 months 2 weeks ago #1
  • mlisk
  • mlisk's Avatar
Hi I need some help cutomizing the menu on one of the subpages. A page I end up when I click on a menue except the '"home" menu.
The backgound of the menu is black with white letters.
I would like to change it wo white with green letters.
I did not find something in the customizer effecting this specific menu situation.
Could you help me what and how to change?
Background of menu on subpages (not home) 11 months 2 weeks ago #2
  • mlisk
  • mlisk's Avatar
I found a point in "analyze" where I could change the color for the background but I don't know how to change it permanent. Maybe that helps to explain what I want to achieve.
Background of menu on subpages (not home) 11 months 2 weeks ago #3
you can change the active menu item color in
>> Customizer > Advanced > Navbar [more] Active Color
The following user(s) said Thank You: mlisk
Background of menu on subpages (not home) 11 months 2 weeks ago #4
  • mlisk
  • mlisk's Avatar
A shame that I did not finf it by myself.
Works fine now.
Thanks for help.
[SOLVED] Background of menu on subpages (not home) 11 months 2 weeks ago #5
  • mlisk
  • mlisk's Avatar
