TOPIC: Single Articles ignores its Options set
Single Articles ignores its Options set 5 years 10 months ago #1
  • vicmarcal
  • vicmarcal's Avatar
Hi!
I have created a Menu Item called "Menu1".
This Menu Item Type is: "Single Article".
The Select Article is: "Room 1".
Room1 is a "Single Article" with Category = Template.
Under Article Options, I am forcing:
"Show Category" to hide.
"Show Author" to hide.
"Show Create-Date" to hide.
So, maybe I am wrong, but the article is supposed to not show its Category, neither Author, neither Create-Date.But, it does: The page is showing all that info.
So seems, somehow the template is ignoring the values forced in the Articles Option?
== Workaround ==
I found what looks a workaround, until a proper fix is released, which is using the Options in the Menu Item, "Menu1", and set "Show Category", "Show Author","Show Create-Date" to Hide insted "Use globals".
But this workaround is a nightmare really, since I am planning to use the "Room 1" article in several Menu Items, so I will be forced to edit all the Menu Items options, instead the easy step of defining how the Article should look like through the Article's options so all the menues would know how to show it.
Single Articles ignores its Options set 5 years 10 months ago #2
You dont have to edit all menu item. You can change the settings in general settings at:
Articles > Options
Attachment options.jpg not found
Single Articles ignores its Options set 5 years 10 months ago #3
  • vicmarcal
Thanks for that fast reply. :)
