TOPIC: problemi con Template Joomlaplates Ice! - JOOMLA 3
problemi con Template Joomlaplates Ice! - JOOMLA 3 1 year 5 months ago #1
  • biocontrol
  • biocontrol's Avatar
Hello everyone!
I need your help. About 6 years ago I created a site by purchasing a Template from Joomzilla (this is the site www.biocontrol.it), now I decided to make a makeover and I bought another template from Joomlapates the name of the template is Ice! (demo.joomlaplates.com/jp_ice/)
Of course I copied all the contents of the old site so as to already have a base to work on.
BUT I met a PROBLEM:
- connecting to a NEW item from a module in the HOME PAGE does not open correctly.
Instead of opening a new page with ONLY the article opens the home page and the article is positioned in the CONTENT (SYSTEM OUTPUT) (where it says Welcome!), The strange thing is that if I connect an old article created with the previous template the window opens correctly.
The attempts were multiple but without any result !!
>> WHAT ABOUT? I am attaching the link to the new site test.biocontrol.it/ the module in question calls "PACCHETTI SALUTE" if you try to click the ENTRA key you will find the example written: PACCHETTI SALUTE proooooovaaaaa !!!!!!
I hope I was clear.
THANK YOU IN ADVANCE EMANUELA
problemi con Template Joomlaplates Ice! - JOOMLA 3 1 year 5 months ago #2
Sorry I cant see any problems.
If you click on the module link you come to the content, see image attached.
Of course you see all other modules. But this depends on the module assignment. If you create a menu item for the Joomla article you can assign the modules to it.
The following user(s) said Thank You: biocontrol
problemi con Template Joomlaplates Ice! - JOOMLA 3 1 year 5 months ago #3
  • biocontrol
Thank you! I can not make ONLY the page with the article, I do not want to show the modules above. I see a menu item and I try.
problemi con Template Joomlaplates Ice! - JOOMLA 3 1 year 5 months ago #4
  • biocontrol
I can not understand. if I link an article created 6 years ago I open ONLY THE PAGE without header and the other modules example "LABORATORIO ANALISI", DIAGNOSTICA PER IMMAGINI ... etc
I WANT TO SEE HOW THE FILE I HAVE ATTACHED!
THANK YOU..
problemi con Template Joomlaplates Ice! - JOOMLA 3 1 year 5 months ago #5
As I told you above.
If you want to have to show only the article without modules you have to create a menu item link for this article and assign the modules > No except these selected
docs.joomla.org/How_do_you_assign_a_module_to_specific_pages%3F
