TOPIC: [SOLVED] Dot Nav Menu
Dot Nav Menu 1 year 4 months ago #1
  • nordin
  • nordin's Avatar
i just unpublished and published the module and the menu can't be seen anymore, can anyone help to bring it back adn set the buttons names? thanks
Dot Nav Menu 1 year 4 months ago #2
Hello, depends on the Joomla editor.
www.joomlaplates.com/support/documentati...content-was-cleansed
The original code can be faound at:
demo.joomlaplates.com/jp_ice/docs/#absolute
Dot Nav Menu 1 year 3 months ago #3
  • nordin
  • nordin's Avatar
thanks a lot for the answer, until i didn't found out that my editor had a limitation and i couldn't insert the code
[SOLVED] Dot Nav Menu 1 year 3 months ago #4
  • nordin
  • nordin's Avatar
