TOPIC: Assigning to Easyblog posts
Assigning to Easyblog posts 2 years 8 hours ago #1
  • ann@webdesignunlimited.co.uk
  • ann@webdesignunlimited.co.uk's Avatar
Have set Inspire template as the default for the site and created a style which I have applied to all pages from within the template Layouts settings and appear to be using correct style everywhere. But when I open an article from the blog page here (using EasyBlog) p11-preview.runhosting.com/valq.com/inde...log&id=14&Itemid=104 it opens using the default style for the template. How can I force it to use the style I have used elsewhere on the site?
Thanks
Assigning to Easyblog posts 1 year 11 months ago #2
Thats possible with layouts!
Create a new layout, assign a style to the new layout and then assign the menu item.
www.joomlaplates.com/support/documentati...profile-to-menu-item
Assigning to Easyblog posts 1 year 11 months ago #3
Thanks for getting back. I don't think I used the right terminology before. I have created a new layout which is assigned to every menu on the site. The problem is when I open a blog post by clicking on one of those shown when viewing on the Blog menu is that it reverts to the default layout for the template. It doesn't open the post using the layout specified for the current menu.
Assigning to Easyblog posts 1 year 11 months ago #4
I think the problem is the duplictaed Template Style.
Please remove the the Style and do it with layouts.
Its not possible to duplicate our themes with Joomla, therefore we´ve created layouts.
Assigning to Easyblog posts 1 year 11 months ago #5
Hello - thanks for your response. Still not sure this is right.
I've created a layout profile and selected the style that the profile should load. I have then within Layouts assigned this to every menu on the site, but when the posts are loaded from the blog menu they are using the default style. At the moment the only way I can see of resolving this is to customise the default style so that it is the same as the style I've created for this site.
Assigning to Easyblog posts 1 year 11 months ago #6
Apologies - all sorted. Have applied by customer style to the Default layout which as resolved issue.
