TOPIC: Footer mobile
Footer mobile 2 years 6 months ago #1
  • mikmedia
  • mikmedia's Avatar
how do I customize a footer for the mobile version?
Tanks
Footer mobile 2 years 6 months ago #2
what do you want to customize exactly?
Footer mobile 2 years 6 months ago #3
  • mikmedia
  • mikmedia's Avatar
I created a custom module for the footer, in the mobile version is not displayed correctly, I would like to have a different module for the footer
Footer mobile 2 years 6 months ago #4
you can hide your module on footer with module class suffix
www.joomlaplates.com/forum/j3-interior/7...mobile-devices#19289
Footer mobile 2 years 6 months ago #5
  • mikmedia
  • mikmedia's Avatar
Thank You, but i tryed and not working.
And if i have the same problem with article?
Footer mobile 2 years 6 months ago #6
Module Class Suffixes are only for modules and not for article.
But you can put a div around your article and insert the class you want to show:
The following user(s) said Thank You: mikmedia
