TOPIC: \"SQL=LOCK TABLES `vrux6_menu` WRITE\" problem
\"SQL=LOCK TABLES `vrux6_menu` WRITE\" problem 7 years 9 months ago #1
  • gpeter
  • gpeter's Avatar
Hello.
I have some problems with editing the JP_Insurance template.
I install Joomla and template, import \"jp_insurance_17.sql\" database and set Database Tables Prefix (\"vrux6_\"). Template with content is now shown correctly, but when I want to edit the mainmenu and topmenu, joomla returned me next error: \"Save failed with the following error: Access denied for user \'user_name\'@\'%\' to database \'database_name\' SQL=LOCK TABLES `vrux6_menu` WRITE\".
I\'m not sure, that the problem is in template, but at my MySQL settings, but however I hope that you can help me with fixing this problem.
Thanks,
Peter
Re:\"SQL=LOCK TABLES `vrux6_menu` WRITE\" problem 7 years 9 months ago #2
  • gpeter
  • gpeter's Avatar
I have same problem, when I want to edit an article.
Re:\"SQL=LOCK TABLES `vrux6_menu` WRITE\" problem 7 years 9 months ago #3
  • Joomlaplates
  • Joomlaplates's Avatar
Did you changed the username and password for your Joomla system? If not, please set a new password and logout and login again.
Re:\"SQL=LOCK TABLES `vrux6_menu` WRITE\" problem 7 years 9 months ago #4
  • gpeter
  • gpeter's Avatar
Try it but it does not fix the problem. Also create one extra user account with \"super user\" rights but still does not work.
Re:\"SQL=LOCK TABLES `vrux6_menu` WRITE\" problem 7 years 9 months ago #5
  • Joomlaplates
Ok, if possible send me Joomla admin account to:
support@joomlaplates.com we will try to look and fix this error.
PHP MyAdmin access would be good too.
