TOPIC: SOLVED : Menuitem Breezingform > Lof ArticlesSlide
SOLVED : Menuitem Breezingform > Lof ArticlesSlide 7 years 1 month ago #1
  • RenM-ITS
  • RenM-ITS's Avatar
The template is functioning perfectly, except for one location.
I installed the component BreezingForms and when go to the menu item, pointing to the form, the Lof ArticlesSlideShow Module seems to get in a loop and keeps displaying the loading icon.
When i setup dat the form is loaded in a iframe or border, the module is loading correctly.
Is there a way to find out why the module cannot load on this menu item? It works perfectly on other menu items.
The website is being setup at the moment: test.www.progress-educations.nl/index.php/inschrijven
Hope someone can help me out here.
Mark
Menuitem Breezingform > Lof ArticlesSlideShow 7 years 1 month ago #2
  • RenM-ITS
  • RenM-ITS's Avatar
It must be related to the module right. There was the module "banner" located. I moved this module to the "banner"-location and now the page cannot be loaded at all anymore.
Menuitem Breezingform > Lof ArticlesSlideShow 7 years 4 weeks ago #3
  • RenM-ITS
  • RenM-ITS's Avatar
The Articleslider is jusing scripts, just as the Breezingform was. Therefore it is conflicting.
Solution : Use other Slider component or us other formbuilder. RSjoomla seems to work ok.
I solved it by unchecking the module assignment for the slider: The menuitem of the Breezingform is now excluded.
With thanks to Peter Kuhlmann, support of Joomlaplates.
