TOPIC: White background in the right side
White background in the right side 1 year 6 months ago #1
  • Ferriero
  • Ferriero's Avatar
Hi!
I don't know what I did but I have a white background in the right side on my site.
www.biciamici.it
White background in the right side 1 year 6 months ago #2
please disable the booking module and it should work.
If yes, you know where the problem is.
The following user(s) said Thank You: Ferriero
White background in the right side 1 year 6 months ago #3
  • Ferriero
  • Ferriero's Avatar
Hi!
I had already tried to disable all the modules but the problem persisted.
The problem was this code into custom.css:
@media (max-width: 768px) {
#menu-outer {position: relative !important}
.main-outer, .top-a-outer, .footer-a-outer, .top-b-outer, .top-c-outer, .top-d-outer, .bottom-a-outer, .bottom-b-outer, .bottom-c-outer, .bottom-d-outer {
padding: 40px;
Thanks!
