TOPIC: Customize Lof ArticlesSlideShow
Customize Lof ArticlesSlideShow 4 years 1 week ago #1
  • vesturdal
  • vesturdal's Avatar
I have used the "Investment" template to create my homepage "tannstovan.fo", when the page was set up 2 years ago, I customized the "Lof ArticlesSlideShow" plugin so when the mouse hoverover a item in the navigator, the item is in focus, the normal behavior is that you need to left-click on the item to get it in focus. Also I changed the behavior so when you left-click on an item in the navigator, it goes to that article, and not as it normally work, where you have to click on the large picture to navigate to an article.
The problem is now that after an Joomla update my changes is gone. When I made the changes last, I found some example on an forum, but after I have been searching around I am not able to find it back.
Is there anyone her that could help me customize the "Lof ArticlesSlideShow" back, so when the mouse is over an item in the navigator the "focus" changes, and when a mouse-click hit a item in the navigator it goes to that articel.
Thanks
Sjúrður Vesturdal
tannstovan.fo
