TOPIC: [SOLVED] change fonts
change fonts 4 years 11 months ago #1
  • afloat
  • afloat's Avatar
How can I add my own font to the template?
I put my font in a folder "fonts" in template folder, and I add a css code to associate the font, but it only works on my pc (but I have my font installed on it) .
Should I add my font in another folder? Maybe in css?
Thank you very much
Francesca
change fonts 4 years 11 months ago #2
Hello, give me a live Url please.
Your fonts are at the right place, but please take a look if the h2 font style will be overridden in any aother file.
If yes you should add an "important" behind the style.
h2 {font-family: 'elkwood' !important}
change fonts 4 years 11 months ago #3
  • afloat
  • afloat's Avatar
Hi, thank you for the answer.
Url is www.conoscenzainfesta.eu, now it's under construction, but I give you visualization access, that is:
Secret text
I try to add an "important" but I think it doesn't work.
change fonts 4 years 11 months ago #4
Hi again,
I think your path to the font is wrong:
Please use ../fonts instead of /fonts
The following user(s) said Thank You: afloat
change fonts 4 years 11 months ago #5
  • afloat
  • afloat's Avatar
Thank you so much. it works!!!
[SOLVED] change fonts 4 years 11 months ago #6
  • afloat
  • afloat's Avatar
