TOPIC: [SOLVED] top-a and top-b
top-a and top-b 2 years 1 month ago #1
  • nordin
  • nordin's Avatar
is there a way to make top-b modules have the same style as top-a or a way to make the top-a modules in two rows and not in a single row, thanks a lot for all the help.
top-a and top-b 2 years 1 month ago #2
  • cg
  • cg's Avatar
Hi nordin,
what about positioning 2 Modules on top-a 2 further modules on top-b assigning parallel to customizer layout option?
Another possibility you can try is making one module nesting the 2 others with modules anywhere or the core function of joomla to insert a module.
A quick and dirty solution is to code a 2 x 2 grid with UIKIT.
top-a and top-b 2 years 1 month ago #3
  • nordin
  • nordin's Avatar
actually was i was aming for is to make top-b look the same as top-a but couldn't find a way to do it, i mean as you can see the shadow box in the back and so on, would you please point me in the right direction to find these settings ?
top-a and top-b 2 years 1 month ago #4
  • cg
  • cg's Avatar
Hi nordin,
I'm not shure I understand your issue.
You know how to assign box-shadow ... to a module depending on the position in the customizer? (see attached file)
In the picture you see different styles of boxes.
[SOLVED] top-a and top-b 2 years 3 weeks ago #5
  • nordin
  • nordin's Avatar
