TOPIC: [SOLVED] New Style for Maximum does not work properly
New Style for Maximum does not work properly 1 year 7 months ago #1
  • rroberto
  • rroberto's Avatar
Hello, I've installed the template and then as mentioned in documentation copied a CSS-style (and renamed).
In the customizer it is showing correctly, but after saving and go online to check, the navigation (hover, etc.) is showing still the old color.
www.baeckerei-brandl.ch/web/
As you can see, the color of logo is F931A2 and I want to have this color for the website as basic color. But the navigation is showing still green.
Same for button/link of "go to top".
Additional: I've just noted that in desktop-version, when I make the screen smaller, the menu is not switching to hamburger-menu; but in your demo is switching.
Can you help me?
Many thanks
Rob
New Style for Maximum does not work properly 1 year 7 months ago #2
please make sure that you have assigned your new style to the default layout.
www.joomlaplates.com/support/documentation/warp-7-layouts
New Style for Maximum does not work properly 1 year 7 months ago #3
  • rroberto
  • rroberto's Avatar
Thank you for help; indeed I had to select the style in the template.
Another point to be solved for me is the height of the logo; I have a logo that is relatively high so I need more height in the Nav-Bar.
Where can I find it in the css?
Thx.
[SOLVED] New Style for Maximum does not work properly 1 year 7 months ago #4
  • rroberto
  • rroberto's Avatar
