TOPIC: Problem with Mosaic in Black/White Template
Problem with Mosaic in Black/White Template 3 months 2 days ago #1
  • opitzlein
  • opitzlein's Avatar
hI!
Can you help me?
If i want to open the mosaic Module, i get the message: 1104 The SELECT would examine more than MAX_JOIN_SIZE rows; check your WHERE and use SET SQL_BIG_SELECTS=1 or SET MAX_JOIN_SIZE=# if the SELECT is okay
What can i do to fix this? Site is: www.eyecatcher.at/eyecatcher2020
Thanks
Jörg
Problem with Mosaic in Black/White Template 3 months 1 day ago #2
seems to be an installation issue.
Please deinstall the roksprocket and install it again
Problem with Mosaic in Black/White Template 3 months 1 hour ago #3
  • opitzlein
Hi!
This is not the solution.
I deleted all form my server and my database and uploaded the quickstart package one more.
The same message: "1104 The SELECT would examine more than MAX_JOIN_SIZE rows; check your WHERE and use SET SQL_BIG_SELECTS=1 or SET MAX_JOIN_SIZE=# if the SELECT is okay"
Whats this?
Problem with Mosaic in Black/White Template 2 months 4 weeks ago #4
Give me access to your site.
Send me the details via mail or WhatsApp
