TOPIC: [SOLVED] About system output need help !
About system output need help ! 5 years 2 weeks ago #1
  • bontavi
  • bontavi's Avatar
Hello! i want to turn off system output to stop showing articles , but if i will do it. Kunena forum stop working too . :(
egrizzly.lt/portal/ - its system output is off .
Forum - egrizzly.lt/portal/forum/index .
About system output need help ! 5 years 2 weeks ago #2
its really easy to disable the system output except on forum site.
- Default Profile > Select system output = no
- Add a new profile, name it like "no-system"
- Select the new profile and set the system output = yes
- Assign the new profile to all forum menu items
The following user(s) said Thank You: bontavi
[SOLVED] About system output need help ! 5 years 2 weeks ago #3
  • bontavi
  • bontavi's Avatar
